Last edit by: IB Advertising
Browse all: Toyota 4Runner Brake Guides
- Toyota 4Runner and Tacoma: How to Replace Brake Line
Step by step instructions for do-it-yourself repairs.
Extended Brake Lines Help??
Well I've search the Board with no luck, so here is yet another extended brake line question.
Anyone have a link or contact for DOT approved extended SS brake lines for a 2001 4Runner? I've contacted AOR4x4 and was told their brake line kits are not DOT approved. Central 4wd kits are for 86-95 4Runners: http://www.central4wd.com/store/itemdetail.asp?ID=2369
The same for Summit Racing, 86-95 4Runners:
http://store.summitracing.com/partde...EDA24B42FFF%7D
Can these be used in my '01 4Runner? Any info or leads is appreciated. Thanks.
I dont know where Gadget got them from, but he has some for the front. Wheelersoffraod has the rears though. From what I understand. when you lift you only gotta do the rear. But I've seen braided lines for the Tacomas over 4wheel autoparts.
Anyone running the 2.5" 4Runner extended brake lines from Wheeler's Off-Road on a 2001/2002 3rd gen? The website says it's for 95.5-2000 4Runners, but any reason why they wouldn't work on a 2002? Front and Rear. It sure seems this'll work, but here's me "playing it safe" by asking first.
I'm gonna be runnning a bit over 2.5" lift in the rear, but this should be better than the stock brake line.
I have the All-pro braided lines. You can buy the rear seperately if you want though. They are real long
Interestingly enough, toyota has used the same fittings since 1979 for rear brake lines. (Or so I was told by All-Pro).
It just screws on with a 10mm wrench.
I've got those lines in my 4Runner.
Charles, why not go w/ Steve's SS brake lines. His go up to 3" of lift. You'd have to confirm on the 01/02 b/c it also says to '00. It's pretty much the same price as wheelers and you're supporting a yotatecher.
Here's a link: http://www.sonoransteel.com/store_brake_line.html
well...i'll tell why i didn't go for that: i didn't know he had that! haha but cool, now i do. so stevie wonder...i'll be ordering that from ya real soon.
Originally Posted by sschaefer3
Ya wanna just put it on when I weld your drop bracket on?
09-04-2015 09:27 AM
pyramid
07-30-2015 10:05 AM
CanRunner
07-20-2015 01:29 PM
