exhaust size..need help
Godzilla's exhaust was measured in feet not inches
Sorry just had to have a crack at it, your screen name leaves a question like that wide open for abuse.
Can't help you, but at least you get a bump!!
![laugh](https://www.yotatech.com/forums/images/smilies/laugh.gif)
Location: White Mountains, Arizona (Yes it does snow in AZ)
Is it a 3.0 or a 2.4L? Makes a difference. I'm guessing 3.0 since you started at 2".... 2" is oem or at least right around where it should be. You can go 2.5" on a 3.0 without running in to backpressure issues. Someone with a 3vze will hopefully chime in.
Hopefully your welding the muffler in right? If you clamp it they never seem to seal right IMO. Just take a chunk of your pipe with you and test fit it in the store/ shop.
Edit: most mufflers are set up to slide over the pipe for easy fit up and welding.
in the magnaflow catalog , for the runner they indicated the 2 inch muffler/pipe..everywhere i turn though its all about 2.25 for power and etc... which should i get?? so so confused
