Exhaust Recom. for 22re
I know most of the 4runner guys use the dynomax super turbo or go with borla. But anyone out there have any recomendations for a 22re 4wd pickup. I was just looking around today and seen a pacesetter setup on jcwhitney. If you guys were to set it up from the header what would you use?
We found out while doing my son's and a friends 22RE, that putting the V6 pipes worked well from the Cat back(same application, just buy the stukk for the V6). We both used V6 pipes and then the "Glasspack" for the muffler (it is usually listed as an optional part). Gave us larger diameter pipes that the parts store didn't think were made of gold, bolted right in (some hanger tweeking), and actually had more power when we were done (speed comparison up a long hill before and after) It cost less than $100.
David
David
Just order the header from NWOR, i can dig out the # tonight, and the muffler setup will depend on how you can plumb it, for example center in, offset out and so forth, but summit racing is the best prices for them.
