ES shock bushings?
You can use sway bar bushings.. They are the same diameter and fit exactly the same as the stock bushings.. That is what I did with a set I had bought for all those quick disconnects...
Hey, if you want to buy a set really cheap let me know... I bid on a set of black ones off e-bay and they are not Energy Suspension bushings and are slightly taller.. They would work for the sway bar links, but I would have to change the measurements.. Here is what they look like..
Just so that you know, the washers under the bushing washer is to space the shocks down for the low profile bump stops..
Shoot me an e-mail.. I have 4 bushings and whashers that would work perfect..
live4soccer7
05-11-2016 07:52 PM
punks_is_4x4
02-26-2016 05:29 PM
