engine strugle
V6 power strugle
hi...my 91 4runner 4wd v6 is acting up....when lightly pressing the gas i feel some shakeing and power jerks then goes....nothing to bad but really a concern......between 50 and 65 when lightly pressing the gas...feels like the back of the truck shakes.....my be an intake issue or spark plug issue....i keep the engine in great condition...anything you can think of.....same issue in my 240sx it's an 89 single cam and it does that a bit also
i've always put in 91 in CA we only have 91, 89, and 87....but the last month i've been puting in 87 gas in......i will change it and use injector cleaner....thanks for the shocks by the way...ome the only way to go....i had to toss those pro comps.....the only worry i have about ome is the travel is stock and my pro comps are 2 inches longer....i have not hit the dirt yet with them...hopefully today if the chick is not PMSing.....i will look into triming the bump stops also to gain travel...is there a good place to get good a arm bushings....one of mine i just changed is broke and the a arm is moving out ward
engine strugle
help my 91 putts....at idel it putts and the engine shakes.....not sure if its spark plugs or wires or exaust cat clogged finally or what....anyone know....someone told me gas but thats not it...putting just started....step on the gas and it drives fine just slower than normal....go to be plugs any way to check if wires are bad or plugs????
thanks, i had drive line issues before...very simaller i will check it out....i got a new fuel filter but have not changed it yet i will.....rear trust bar...i just asked barb....some other people think its a spark plug issue or plug wire????
jasonty
41
12-23-2018 02:00 PM
Seattle_Sign_Guy
07-12-2015 01:38 PM
