Engine speeds up when heat is on?
Old 12-05-2006 | 04:46 AM
mtrdrms's Avatar
I have a 98 2wd Taco with the small 4 cyl and its getting pretty cold here in CT. Now when I turn on the heat (more specifically the fan) it sounds like the AC compressor kicks on. The engine speeds up and lurches the truck a bit (its an auto). If I turn the fan off it stops and it doesnt happen all the time. Any ideas? Is this normal? Thanks.
Old 12-05-2006 | 05:38 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Is the A/C on? Many of the Toyotas will also kick the compressor on when your climate control setting is in the defrost mode but the A/C indicator won't light up. The idle speed will increase when it does. Pop the hood and turn on the fan. You should be able to see if the compressor starts.
Old 12-05-2006 | 07:18 AM
mtrdrms's Avatar
Well that would explain it. Thanks!
Old 12-05-2006 | 07:28 AM
Red Neck Bill's Avatar
When i turn the heat on to defrost my windows in the morning it does the same thing i guess thats normal for yotas if not sombody please correct me.
Old 12-05-2006 | 07:40 AM
MTL_4runner's Avatar
If you have it on defrost then yes, the AC does cycle and yes, it is totally normal.
Old 12-05-2006 | 09:15 AM
Rick F.'s Avatar
Having the compressor kick on when i turn on "Defrost" is fine by me. You can't defrost ˟˟˟˟˟ by blowing moist air on the inside of the window... I could never figure out why my old domestics didn't do that. But then, that's one of many reasons I didn't like my domestics...
Old 12-05-2006 | 09:26 AM
YotaFun's Avatar
My 95' Olds Did it intermitently...
Sometiems It would turn on the AC on defrost mode...
And sometimes I would have to turn it on manually...
Now I don't have to worry about it...
Gotta love Yotas!!!
smthwsn357
05-01-2024 08:28 AM
bigjstang
08-25-2021 01:41 AM
87blyota
07-10-2015 05:31 AM
wilbertd
07-06-2015 08:39 AM
