Engine is locked, Choices to make?
Old 01-28-2006, 08:45 AM
Yoda's Avatar
Might try removing the starter. I have seen an incorrect starter installed (wasn't a Toy, but could happen there too) that totally locked the flywheel.
Old 01-28-2006, 09:14 AM
Weasy2k's Avatar
Originally Posted by k_r_o_w
I turned the key over to put into neutral all of the dash lights were coming on.
Once again thanks for the help.
?? This didnt happen before?
Follow the lists made above and from there continue, i also agree witht he sludging problem as all toyota v6's had that problem when running regular oil.
It had to do with poor crankcase vent system.
I will upload some pictures of the difference between running synthetic and non-synthetic in these engines.
Old 01-28-2006, 10:12 AM
KyleT's Avatar
ok, sorry to hijack, i run castrol syntec blend, will that cause the sludging also? im at 143k now, and have been runnin that for 10k since i bought it. im assuming the guy that had it before me ran dino oil, as it had a kwick kar sticker on teh windshield, and when i changed it. i dont want any problems right now.
Old 01-28-2006, 10:24 AM
Weasy2k's Avatar
anything is better then regualr oil....
even preforming a engine flush will help
Its not a disaster but for some reason these v6's suffer from this problem vs any other toyota engine.
Old 01-30-2006, 06:09 AM
  #25
Actually Toyota also had sludge problems on 4 cylinders Camry as well (From 1997 to 2002).
arlindsay1992
01-23-2024 01:34 PM
06-01-2021 01:51 PM
God's Bounty Hunter
07-08-2015 12:54 PM
Bamripzit
06-20-2015 04:53 AM
Quick Reply: Engine is locked, Choices to make?
