elocker '01 4runner issues
ok so assuming a lockrite is an example of ratcheting, which would be an example of a LSD? because judging by your explaination it seems if i do not want to spring for the selectable arb or e-locker, the LSD would be the best way to go for a DD.
also do you know what the difference is in the detroit, and the detroit true trac?
The truetrac is an LSD (and the only one I know of that's made for our diffs), the normal Detroit is a ratcheting (aka lunch box) locker. The truetrac will not perform quite as well off road as a lunch box, but will still be a big improvement over an open diff and have much better on road handling. It sounds like that would be a good choice for you unless you plan on doing more and more wheeling in the future.
after putting prices together i dont know if i can afford the lockers right now. is it ok to run 5.29s open i just scheduled work to be done on my house and dont really have the money to be spending like this right now. i really didnt plan to be re-gearing at this time.
You can run the 5.29's open, its just preferable to put the locker in when you regear since you already have the diff out and open. If you can't afford it then wait, lunchbox lockers aren't hard to install yourself.
#25
i know its a little late, but i just wanted to update everyone on what i ended up doing. i regeared to 5.29 and i used the detroit true trac LSD. the truck drives great and way better gas milage and towing ability. i dont feel like im beating the piss out of it anymore. off road traction has also greatly improved.thanks again for the help and info!
#26
