Electric fan for my 2nd gen
Old 06-05-2004 | 09:10 PM
  #41
rimpainter.com's Avatar
This is the backside of the stock fan on the 5vz. See the outermost piece? If I try and turn that at any time, I have to really crank it with my hand. It has a lot of drag, even in a "cold" condition. A lot of drag for an engine? Not really...but it is parasitic drag none the less. Under heat soak conditions, the entire fan comes into play (see fan roar). No matter how you look at it, an electric fan mod, while not in use is superior to the stock fan.
Someone dyno this mod already!
Old 12-31-2005 | 02:46 PM
  #42
Radyota's Avatar
Originally Posted by <96 Runner>
Not to be antagonistic, but name a RWD that run's an electric fan as it's primary air cooling mechanism.
The mid-80's Ford Mustang/Mercury Capri 4 cylinders had electric fans.
Old 10-09-2009 | 10:08 AM
  #43
crawlerjunkie's Avatar
Originally Posted by Robinhood150
Oh, and just to point out how much we're all nitpicking here and how trivial it is, the taurus fan on high uses 40 amps continuous. P=IV=40x12=480 Watts. That's only 0.6 HP. Assuming the aerodynamic drag of the mechanical fan and the electrical fan is the same, the mechanical fan will use about the same HP.
123456767889.......see i can spit out random numbers to
coryc85
09-09-2015 07:24 AM
izzmee
08-17-2015 11:20 AM
g3bill2
08-07-2015 08:04 AM
vanion2
07-29-2015 07:17 PM
Steezy96yota
07-06-2015 11:00 AM
