Egr Valve
Old 02-26-2004 | 05:12 AM
callmej75's Avatar
Originally Posted by foxtrapper
You should get a set of intake manifold gaskets. Many have reused the old ones, but it's a poor practice.
Carburetor cleaner and a toothbrush do a dandy job of cleaning away the carbon gunk. Frequently it's so thick that you can do the first round with a flat blade screwdriver, scraping it out. Lacquer thinner is also a dandy solvent. If you do this job with the lower manifold on the engine, remember, one of those intake valves is going to be open. Don't fill a cylinder up with junk. It's not good for the engine.
right on...thanks foxtrapper and ill keep that in mind about the lower intake manifold. im going in saturday to do the job! appreciate the help!
Old 04-06-2010 | 02:19 PM
aa1911's Avatar
I pulled mine on my 3vz-e a while back to get to the PCV valve which was a PITA, but cleaned out an incredible amount of buildup with TB cleaner and a brush. cleaned T/B and air intake, replaced filter and tested all the sensors. I need to clean out the EGR itself I think though, I had the same problem where it would have a rough low rpm idle and almost stall on a warm start, usually no problems on a cold start. Driving made it go away but annoying when stopped on an uphill slope with a manual trying to feather the gas pedal. After cleaning the intake plenum and T/B and a few other places, it pretty much went away; haven't had issues since.
I just used Throttle body cleaner I think on the intake plenum. 156k at that point.
idadan208
09-07-2015 10:06 AM
Scatterbrain
09-03-2015 07:46 PM
montanatruck
07-25-2015 04:45 AM
Poppie51
07-23-2015 06:03 PM
Poppie51
07-16-2015 07:16 PM
