EGR help
Thats a tuff one .I dried to clean mine the other day & the only thing that did anything was a screwdriver(flathead) .It was scraping off large amounts of black stuff.but i doubt this was very effective.
Hey I just pluged the vacuum line that comes out of the top of the Egr,I wanted to see if this made any differance,then i could assume that my Egr was hadit.Anyway you would not believe the change,Throttle response has improved out of sight.It pulls up to speed much easier,Less pedal is needed(im barely touching it),all & all its just going heaps better.I think i might leave it pluged.
NB. Remember if you want to try this ,you need to take the line off the Egr ,leaving it on the vacuum piping.then seal the loose end of the line.I used one of those little screws that you get with DIY elctrical light switch's or Plugs( house ).It was a perfect fit.
kawazx636
10-06-2021 03:03 PM
Longbed 90
10-19-2015 11:05 AM
accuracy
09-20-2015 07:44 PM
