Ebay Engine Rebuild Kits.. junk?
These any good? For the price I'm sure they can't be beaten.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33620
Just wondering.
Just wondering.
Originally Posted by blink
most of that stuff looks like aftermarket parts and not quality oem toyota parts.
Originally Posted by DudeBud
if you are looking to buy on ebay buy from engnbldr he is also a member of this forum
this is the one you want..
quality engine rebuild kit
if you havbe any doubts look at his feedback
Originally Posted by Ganoid
I agree completly!
Originally Posted by mt_goat
Yeah really, with 6244 transactions and a 100% positive feedback, that says a lot.
sorry for hijacking, but I have never gotten a straight answer about OS valves. What exactly needs to be done to the head in order to run OS valves? Is there anything else that should be done along side the valves to optimize performance? And how much would the work to the head cost to put the OS valves in?
Or call Tod here, weekdays at 503-257-7947
When installing the oversize valves, the machine shop should do a bit more than just cut the seats out larger. We also want to open the throat (bowl in some areas) and the amount is slight but matters. All other dimensions such as guides, standing height, springs, retainers, locks, ...are all stock specs.
Combined with the larger head size by actually less than 1mm ( A LOT of surface area if you do the math) we see volume improvements close to 10%. Now that doesn't sound like much, but the computer must be able to respond and adjust, etc.
Simple to install the oversize valves, just machine the seats out to fit, clean up the obvious areas in the bowl that result...Easy stuff.....*EB
my engine has more ROCK components than toyota. holding up fine if you ask me
toyota parts are good, but typically expensive and not necessary for a good running engine. it's all in the tolerances if you ask me, though these seem to be rather forgiving mills.
It's PUUUUURRRRRRTY.
