Early 1st-Gen Disc Brake Question
Old 04-17-2013 | 10:05 AM
scoostraw's Avatar
One front caliper on my '95 has begun to seize up, so I'll be replacing it soon. From reading, it appears to me that the early - 95-96 (97?) - tacos had a different front disc design.
It looks like that to replace the rotor on my 95, the hub bearing must come off. While on later 1st-gens the disc is just held on with the lug bolts.
Am I right on this? Are the calipers the same - and just the rotor/hub design changed? (I definitely have a 4-piston caliper)
'95 4x4 SR5 Extended Cab V6 5-Speed
__________________
  • 1999 Tacoma 4x4 Standard Cab, 2.7l 5-speed (Repurchased by Toyota)
  • 2000 Tacoma 4x4 Extended Cab, 3.4l automatic (Repurchased by Toyota)
  • 2001 Tacoma Prerunner TRD Extended Cab, 2.7l automatic
  • 1995 Tacoma 4x4 Extended Cab, 3.4l 5-speed
Old 04-17-2013 | 11:53 AM
zipposrule's Avatar
i had a 97 taco and now have a 95, as far as i have seen so far everything is the same.
Old 04-17-2013 | 11:55 AM
scoostraw's Avatar
That would make sense to me, as I believe maybe it was changed in 98(?)
Old 04-17-2013 | 02:55 PM
zipposrule's Avatar
well i know for sure i didnt have to take the hub bearing off my 97. i parted the truck out and the rotors came right off lol
Old 04-17-2013 | 03:45 PM
scoostraw's Avatar
I just looked at the rotor on napa's web site. If the illustrations are correct, it shows the kind that come right off also.
The online autozone repair guide and the chilton manual both describe removing the hub bearings. I'll find out soon when I have the chance to replace that caliper.
Old 04-22-2013 | 04:25 PM
scoostraw's Avatar
I confirmed this today as I replaced the bad caliper. The rotor came right off (held in place by the lug nuts).
So the online Autozone repair guide as well as the chilton manual are both incorrect, which is a good thing to know.
Old 04-22-2013 | 04:31 PM
j2the-e's Avatar
You probably looked at the book for a 95 pickup. Tacomas came out mid year and were considered 95 1/2.
Old 04-22-2013 | 04:38 PM
scoostraw's Avatar
Good point. The chilton book I believe does cover the pickups as well as the Tacomas. Maybe I was looking at the wrong section.
The Autozone site though specifically is showing the wrong information for the 95 Tacoma.
If any of you guys know where I can download the Toyota FSM I'd sure appreciate it if you'd pm me.
fountain
12-31-2015 07:08 AM
09-04-2015 10:27 AM
CanRunner
07-20-2015 02:29 PM
87turboPA
07-12-2015 08:49 AM
87turboPA
07-09-2015 06:58 AM
