E3 Spark Plugs - Hype or Hot Stuff?
All HYPE!!!!! yes I tried them
How many miles do you have on them? Not enough they will do like any other than denso or ngk start to fade till you start bogging. If you want to try a new plug try NGK BKUR7-ET this is a 2 steps cooler plug that is really primarily used in S/C apps but I do like them with out S/C. but that is my opinion. they have a copper core and 3 ground straps as opposed to 2 and all cooler plugs use a resistor in the plug. my truck started running at a lower RPM about 750 unless the a/c is on then it bumps up to a 1000. my experience.
this will give slightly better milage but not any thing to boast about!
Hi, eddieleephd!
Could you let me know if this NGK Standard Resistor Spark Plug 7873 BKUR7ET Set of 6 (EBAY ITEM # 320787896211) fit on my Runner 1998 SR5 4x4 6cil?
Thanks,
88runnergomas
07-09-2015 01:12 PM
