E-locker wiring success!
Old 08-20-2004 | 12:02 PM
p1michaud's Avatar
Talking E-locker wiring success!
Well, last night after two days of scanning wiring diagrams, soldering, heat shrink, running to the store to pick up parts and a mess of wire I finally completed my custom E-locker wiring harness. I used a factory RR Diff Lock switch, ECU, short wiring harness with breather tube for the E-locker electric motor, switch (to replace the 4WD safety and act as an interlock), modified indicating light plus a ton of solder, wire, heat shrink and beer!
When all the connections were soldered and heat shrunk wrapped I had one real mess sitting on the workbench and was a bit worried. I stood back had another cold one and decided to go for the test run. I hooked everything up to a spare car battery. The E-locker electric motor was just in the vise for testing purposes and I hit the lock switch. To my delight my indication light flashed and the motor worked! I was not until I jumpered the limit switch that the indication light came in solid, as per original design. I activated the motor back and forth half a dozen times and just about started dancing for joy in the garage when everything worked! My buddy thought I had lost my mind after seeing the mess of wires but he was impressed when it all worked.
I will try and post pics when I get the home computer fixed. It just crashed last night.
Project summary/status:
1-Install an E-locker in my 99 Tacoma
2-Purchased an E-locked 96 4Runner rear end, drum to drum but the housing might be bent.
3-Phase 1: Make a wiring harness for the E-locker. Completed E-locker wiring harness and tested.
4-Phase 2: Re gear 3rd member. The gears are on their way.
5-Phase 3: Either modify the 4Runner housing (cut all 4 Runner parts off and weld on spring perches for the Taco or find a used Taco E-locked housing.
All I can say is that you guys rock! Your help definitely helped make this phase of the locker project successful. Thanks a million guys.
Cheers,
P
Old 08-20-2004 | 12:04 PM
rimpainter.com's Avatar
Great job! I hope I am next to be jumping around in my garage like a lunatic!
Old 08-20-2004 | 12:07 PM
Bob_98SR5's Avatar
pierre,
did the download of the manuals off the TIS site (linked in the Maintenance section) help contribute to the successful install?
Heh heh
Good job
Bob
Old 08-20-2004 | 03:39 PM
p1michaud's Avatar
Pics have been added...
Hi again fellas.
Yes the FSM downloads did help but most of the schematics I have seen in various postings here were bang on as well. I ran into a problem with the downloaded FSMs, my cpu died 1 day ago with all that valuable info stuck on the hard drive!
Right now, I am in the process of uploading pics, under the E-locker project album:
http://community.webshots.com/user/p1michaud
Again this forum rocks...
Cheers,
P
Old 08-20-2004 | 11:48 PM
914runner's Avatar
I have my rig wired up for an E-locker, now I just need to find one!
06-01-2021 02:51 PM
sanctfy
All Other Toyota Swaps
09-15-2015 03:52 PM
80Truck
07-24-2015 04:12 PM
PureTacoma_Tundra
PureTacoma_Tundra
07-23-2015 12:20 PM
AaronM
07-08-2015 08:15 PM
