drum brake help asap!!
If so your probably going to have the same problem down the road.
Star wheel could be gumed up causing it not to adjust when pulling on e-brake.
Just my two cents worth.
It actually wasn't too bad, but I cleaned it up more and I need to do the self adjust with ebrake some more today.
When I had a similar experience, I over-adjusted the shoes a bit. On my first drive down the road, the drums got real hot. I could smell them when I got out of the truck.
So, check them for heat occasionally (simply by touching the wheels) , to make sure the shoes aren't too close to the drums.
FS[PacSouthWest]: 8-Inch Axle, '97 4R, 4.10, Drum to Drum-Complete
SharpStick
08-29-2015 12:59 PM
CanRunner
07-20-2015 01:29 PM
