Driver side seat belt indicator
Old 07-27-2006 | 04:08 PM
matt11601's Avatar
Hey everyone, just had a quick question about the wire that runs under the driver seat that tells you whether the seat belt is in or not. When I was examinging the wire I found two wires, yellow/black and white/black. Which one is ground and which one is power?
And just to be 100% sure, this is a switched wire right?
Thanks for the help.
-Matt
Old 07-31-2006 | 10:29 PM
tom_mag's Avatar
I'm not sure which is hot and which is ground, but if you cut them then the stupid seat belt minder bell will stop buzzing. Just cover the ends with electrical tape to keep them from shorting to metal. And always wear your seatbelt (I just can't stand the noise)
Old 07-31-2006 | 10:34 PM
matt11601's Avatar
Got it, thanks.
Old 07-31-2006 | 11:08 PM
Bob_98SR5's Avatar
is there a reason why you would cut it vs just simply unplugging the harness?
Old 08-01-2006 | 12:22 AM
Ringmaster's Avatar
I kinda wondered that too...Mine just unplugged and no more buzzer or annoying light in the dash.
lledwod
08-30-2016 02:03 PM
thefishguy77
07-30-2015 11:59 AM
msane99
07-17-2015 11:13 AM
razorman8669
07-12-2015 01:13 PM
crashburnoveride
07-10-2015 07:39 AM
