Driveline vibration on 1st gen 4runner
I just bought a used 88 4runner yesterday and noticed that when decelerating in gear, there is a vibration coming from the rear end of the vehicle. anyone have experience with this? maybe a u-joint or the diff? I got a good deal on it too-- only 2000 dollars, no dents, came with 33's, slider bars and the engine runs well!
oh, one other question, the owner never put it in 4WD in about 4 years, is there some type of maintenance that needs to be done to the transfer case or the front axles?
Tim
Tim
Ya, bad u-joints can cause a driveline virbration, but you usually notice it all the time (not just decelerating). Also, it could be that the driveshaft needs balanced...I read about that a few times as well. Since your rig is 15 years old, replacing the u-joints wouldn't be a bad idea anyway.
thanks dude..
just for fun, i took the rearend out and had it rebuilt and put a new u joint in the driveline. the vibrations gone now-- and so is the funky whining noise from the rearend.
T
T
Originally posted by Duffdog
tjust for fun, i took the rearend out
yea, that is loads of fun isnt it?
I'd change the front diff fluid and if you have manual hubs, take off the 8 or so 10mm bolts and look inside and see if there is still some grease in there. 4 years without 4x4, with 33's and sliders? I dont get it.
can you change the front diff fluid easily? like i wont have to disconnect any belts or brackets or stuff like that?
--o ya, the sliders really arent sliders, they are the fake-ass nerf step bars that bolt to the shackle mounts. The people that owned it before me just bought it for groceries and driving around the city, i think it was the owners before them that had the problem....
T
T
How do you change U-joints?
I assume you pull the drive shaft off, but do you have to get a special tool? I have a bit of vibration at hwy speeds and mine is an 87' 4Runner.
Thanks
Thanks
first of all- before pulling off the driveshaft, reach under there and try to shake it up and down, back and forth. if there is any movement in the driveline at the u-joints, then change them. my u joints were actually burned and expanded and there were no needle bearings left--just metal grinding on metal. the manual says to use a hydraulic press to remove the cups, but i broke my vice doing that and elected to just use a big ass hammer and a socket that matched the diameter of the cup. after an hour of hammering, the u joint just fell out.
Tim
Tim
06-01-2021 01:51 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
