Drag Link failure
Drag Link failure
I was on my way to work today when my drag link went out! DOH!
does anyone know where to get a replacement besides the dealer? the dealer wants $156 for it!
On your '91? You don't have a drag link on the '91. Do you mean one of the tie rod ends, the pitman arm, idler arm, or the relay rod (center section that connects the pitman arm to the idler arm)?
drag link failure
you may want to check the dealer to see if it's covered under that new recall
here is the info
NHTSA CAMPAIGN ID Number : 05V389000
http://www.nhtsa.gov/
good luck
here is the info
good luck
ON CERTAIN PICKUP TRUCKS AND SPORT UTILITY VEHICLES, IF THE STEERING WHEEL IS REPEATEDLY TURNED UNDER CERTAIN CONDITIONS WHERE HIGH STEERING EFFORT AND POWER ASSIST ARE REQUIRED, FOR INSTANCE, WHEN FULLY TURNING THE WHEEL WHILE THE VEHICLE IS STOPPED, A FATIGUE CRACK MAY DEVELOP IN THE STEERING RELAY ROD.
thats EXACTLY what happened! im on hold with Toyota right now and they are checking my vin to see if my truck falls under the recall.
here is the info
good luck
here is the info
good luck
http://www.4crawler.com/4x4/TLCA_Tru...ech.05.11.html
All Fixed
i dropped my yota off at the Cerritos Toyota dealer on Monday and they had it fixed by that afternoon, no charge, and they paid for my towing! NICE job Toyota! I just havent had the time to pick it up yet.
live4soccer7
05-11-2016 06:52 PM
myotherrideisayoshi
09-29-2015 05:41 AM
