DR Z Silencer MOD
#41
Hmm. I do like the flexibility of the stock tube, it allows for the throttle body spacer which I am getting next week. And we all know the TB spacer adds 20HP.
Seriously, I am getting the spacer, and I will do a write up on it. Whether or not people like, I dont really care. I had it on my 98 and loved it.
My point is that this cool looking intake tube may not allow for the extra 1" needed for the spacer. Just a thought.
#42
I have the helix throttle body spacer. I was thinking about keeping some of the rubber stock tube on either end, and using flexible plumbing couplings to connect the tube in between- probably still alot cheaper than the Volant set-up
#43
Yeah, I am actually surprised there aren't more people concentrating some custom fabrication on the intake piping itself. Maybe we can start a trend.
Doesnt Volant make ski's anyway?
This is probably drifting off topic, but it still has to do with the intake...
#46
Originally posted by Tatsuo
I just went ahead and did it on my '91 3.0 and I am very happy with it, there is a lot more low end torque then before.
It's a great bang-for-the-buck mod. Coupled with the deckplate, it's THE bang-for-the-buck mod!
#49
i would concentrate on being able to suck in cold air rather than hot, that would prob give you most the performance gain yet.
just my pennies...
#50
He might have been talking about the 3.4, not the 3.0. I dont think there is a deckplate mod for the 3.0.
#51
Well then, it's time to make one... i'll try to get around to it in the next couple of weeks. Take lots of pictures... assuming I am successful
And yes, my throttle response has improved greatly!
#52
1 Post
I posted this as an unrelated adendum on another thread, but I think it is worth posting here where it is pertinent to the topic.
I just finished doing the ISR mod. I sent pictures of the prototype to Dr.Z. since I have not figured out how to post pics here on the board yet. If he is able to receive them he is welcome to post them.
In essence, what I did was to get a 5-1/2” long piece of electrical grade PVC with a 2-1/2” ID. I measured in 3/4” on either end and shaved the tubing wall down about 1/8” and in from the end to that ¾” mark. I then beveled the inside wall from about 3/8” in out to the end so that the end thickness was about 1/16”. This was so that when the tube was installed the airflow would not hit a ‘step’ that would interrupt the airflow and create turbulence. The best way to machine the PVC pipe is to use a lathe, but since I didn’t have one I used my high-speed die grinder and a grinding stone. I made a jig and went to work.
I am not going to make any comments on observations at this time, BUT ...
1) Could throttle response be more immediate?
2) Could my in-gear at idle vacuum be up 1 IN Hg?
3) Could my acceleration be smoother?
4) Could my cruise vacuum pressure be up from 1- 2 In Hg?
What I will say is that the ISR pipe came out very well and fits perfectly. The main thing is that there must not be ANY air leaks at the connections.
BTW: Cost for this mod was ....
1 hour of my time ... the pipe was free.
#54
Originally posted by kaneman23
Where can I find info on the ISR mod? Is there a link or any instructions to eliminating the silencer?
https://www.yotatech.com/~corey/tech...ntake/dr_z.htm
Have fun!
#56
heh. "welcome".
What year/engine/make is your rig?
[edit] nevermind... You have it in your profile. I get this confused, but I think that you'll have trouble with the ISR mod on the 2003. You'll have to take a look at it and see what you think. There's also a good bit of info here... try searching for "2003 ISR" (no quotes) and see what pops up.
#57
ISR Mod
I Guess Thanks is in order for both Dr. Z and ManyMods. I did the ISR Mod today with the electrical conduit. I haven't noticed a significant power increase, but it is much louder. A lot louder than I expected. I will post when I have had a chance to drive it more.
#58
Re: ISR Mod
My .02
Dr. Z
#59
I have had the deckplate and an Amsoil for quitea while now. The deckplate made a huge difference. Exhaust is next. Can I ask what you paid for yours? Can I order one on-line?
#60
1 Post
Go to: <http://www.beckson.com/index.shtml> to order the deckplate; it costs about $10.00. Get it in black with the clear screw-in cover.
For anyone who doesn't know it already , I have a TRD catback system for sale for the dual-cat exhausts. I want $400.00 plus shipping. It is in excellent condition with only 3700 miles of use. It has a side-exit stainless slantcut round tip.
Regarding the ISR, I painted the gray tube with Eastwood's black bumper paint. I wiped the exterior with acetone first to remove the sheen. Acetone will attack the plastic so be swift with your swiping.
