doors off on a 3rd gen
Old 09-02-2007 | 07:53 PM
james4060's Avatar
alright i was wondering if anyone has taken the doors off on their third gen. if so how difficult is it and would it be illegal in georgia?
Old 09-02-2007 | 09:47 PM
Yota Runner's Avatar
I dont remember who but I've seen a pic in the member rides of a 3rd gen 4runner with its front doors off. My guess would be to sift though the members rides untill you find it then send them a PM. Maybe someone will chime in and give you a specific member to research but untill then thats were I would start.....sorry I couldn't be more help...good luck
Old 09-02-2007 | 09:52 PM
Elton's Avatar
mmm lets see need to take the kick panels off unplug the wiring harness for the door pull the harness out cut the speaker wires ? then take the 4 bolts holding the door on
Fo_SheeZy's Avatar
cubuff4runner has.
Old 09-02-2007 | 09:53 PM
bigtrucknwheels's Avatar
From: Where it always works if you work it, in Sunny Selinsgrove, PA
from my understanding, you must have mirrors on your vehicle, in most states anyways. so if you remove your doors, you need mirrors mounted, say, on your fenders.
imo, i doubt its all that hard to pull them off. wait, you got wires in the doors. youd have to rig something up, some kind of quick disconnect system. the hinges themselves arent bad at all. just get help removing/rehanging the doors, unless you have a door holder tool thing.
Old 09-03-2007 | 10:00 AM
HuskyRunner's Avatar
The pic above has a small mirror attached to the rollcage.
Old 09-03-2007 | 12:01 PM
tacomakid16's Avatar
i asked the same question about my taco and got 30 different answers lol
Old 09-03-2007 | 02:31 PM
Rock Slide's Avatar
Removing the doors is easy...4 bolts per door to remove and a few wires.
As far as it being legal or illegal, call your local or state officials.
I know a guy that's removed all 4 doors on his '96 4Runner here in AL and has had them off for 2 months now w/o any police issues. Granted, he also has a mirror mounted to his left front fender
Check out JHupp's 4Runner. He's taken his front doors off before on his 3rd Gen (scroll about 3/4s the way down): https://www.yotatech.com/forums/f79/...1-sport-78623/
Old 09-03-2007 | 07:04 PM
rocket's Avatar
I'm in the middle of a major stereo upgrade so i took a couple pics that shows what needs to be done.
Take the inside kick panel off.
Disconnect two wire harnesses (one blue, one black).
Detach the accordion rubber boot. Each hinge has 2 bolts.
In between the two hinges, theres a center hinge (not sure whats it's called). It has a plastic cover that pops off, exposing the bolt to remove it. Thats all.
Old 09-04-2007 | 07:45 AM
cubuff4runner's Avatar
As mentioned in the last couple of posts they are pretty easy to remove. 4 Bolts 1 screw and unplug two harnesses and they come off. Many states don't have laws against not having doors, but you usually need a driver side mirror and most of the time you are supposed to have a 3" lip on the floor.
06-01-2021 02:51 PM
jerusry
10-19-2015 06:28 PM
snap-on
08-10-2015 06:19 PM
ChiefTetlow
08-10-2015 05:19 AM
JAMGarcia
7
08-01-2015 12:46 AM
