Does The Weight Of A Grill Guard Reduce Tread Life?
Looks like I'm going to have to replace my tires at only about 20-30k. (thats in kilometres!) I bought these 2 years ago, I have never had to buy 2 sets of tires for one vehicle. So do you think the grill guard, would cause this premature wear? The tires were rotated on a regular basis, there's no camber wear, I haven't been doing burnouts or anything stupid like that. The tread wear on all tires are all even. :S I'm pretty much stumped whether or not I should I sell my Manik Grill guard.
February 29, 2004, A couple of days before the grill guard was installed
Monday, October 04, 2004, just over 6 months after it is installed
A lot of tread is gone for 6 months...
Looks to here like the outside edge of the tread is worn more than the center...is that true when you look at them? If so, could be underinflated chronically, or the toe-in on your alignment could be out of adjustment. Incidentally, NO, the weight of a grille guard isn't going to measurably affect your tread life. Not at all. How are the back tires?
I have the manik grille guard on my truck also with over 45k when first installed-- no signs of tread wear on my tires--I rotate regularly as you do--- must agree with everyone else-- underinflated tires or just bad alignment... have both checked out... BFG tires are great-- I have the same ones you are using on my wifes RAV4 with over 50k and a pretty good decent amount of tread life left...
ive owned my runner since oct '03, it has had a grille guard from day one. when i bought it, the tires were pretty much dead, and the dealer threw on the dulop radial rover a/t's i have now. treadlife has been great (little to no wear), and there is no need to change my tires whatsoever almost 20K later.
i dont think the guard is the culprit.
I had the tires for about 6months right before I put the grill guard on, with regular rotation and etc, it had no sign of wear until I put the grill guard. If anybody's interested in a 96-98 Manik Grill Guard just let me know. Thanks for all your inputs.
Originally Posted by hilandfrog
nice patch, what years were you there? I was at ONE from 90 to 02.
VR
Repo
VR
Repo
EDIT: I wasn't a pecker checker back then...
Chris Forrest (ST-1 same time as me) is in Montana now too.
a grille guard will add more weight to the front end... however that should have no effect on the tires as long as they arent overlaoded.. im i am sure no tire is going to get overloaded on a stock vehicle thats got maybe 100 extra pounds on it... its most likely mroe a tire issue or crappy tires....
ashamsuddin
17
07-22-2024 04:59 AM
live4soccer7
05-11-2016 07:52 PM
smilen724
13
11-08-2015 05:11 PM
Dale Johnston
11
10-31-2015 11:22 PM
bryan34w
12
09-30-2015 03:50 PM
