Does anyone else notice this
Old 04-12-2004 | 09:23 AM
SLC Punk's Avatar
Originally Posted by Churnd
So how much is too much? I usually round mine up to the nearest quarter or half dollar (I'm anal about that), which sometimes takes a few extra clicks to get to. I hope I'm not doing any harm.
I do the same thing. I fill it, then let it auto stop, take the nozzle out for a few seconds and then let it drain, then put it back in and let it auto stop again. Then just round $.
You will be fine rounding it. Just don't fill it so far its at the top of the filler neck.
Old 04-12-2004 | 10:11 AM
2001Millrunner's Avatar
Originally Posted by bulldog-yota
Not sure about the 4Runner, but some manufacturers have a "little breathing" room in the tank. This is susposudly to avoid the bursting of the tank in an accident. ANybody familiar with this on the 4Runner?
I have a 4th Gen and normally put in about 20 gal when the light starts coming on. The most I have put in was 22 gal. I have not tried to add an extra few.
I believe the little hole right below the main pipe and that's what it's for
Old 04-12-2004 | 02:47 PM
LarsDennert's Avatar
There is a defective breather in the 3rd Gen 4Runner. Usually you can squeeze another gallon in after is "clicks" off. I just did quite a bit of TSB research. Check my web page. I also just filled up my tank this morning with 18.5 gallons. Even the TSB breather sticks down far enough to leave an air gap for expansion. The evap breather (different than the defective fill breather) is high enough to keep from sucking juice unless you REALLY over fill the tank. The reason everyone only fills 14-15 gal is because the gauge sender is inaccurate. You can go another 100 miles (sometimes) after the warning light comes on.
Old 04-12-2004 | 05:05 PM
Firefyter-Emt's Avatar
A friend of mine has this trick, to change the subject a bit, with payment via CC. What is does is to put in say $20.57 or $17.57 but always .57 He say's that no one else will ever do this, and if his CC# is hi-jacked at a gas station and he will find it right away.. Dang good idea I say.
markf1
09-03-2015 02:23 AM
snap-on
08-11-2015 05:41 PM
romex1
08-10-2015 07:21 PM
ripp96
07-25-2015 03:32 PM
horunner1x
07-10-2015 07:33 AM
