Do your trucks/4runners wander?
Hey, I'm up in Lake Forest Park. Also have the same issue with my '98. Front end alignment helped a bit. My Revo's seem to wander on me alot more than when I've got the 33" MTs on the rig. I'm thinking about trying new bushings on the a-arms to see if that helps.
Mine drives straight on even terrain, but Lord help me if I hit a big pothole at highway speed - that usually throws it hard in one direction or the other. I have new and properly balanced tires, so it's between the steering bushings, which are relatively inexpensive to replace, and the suspension being shot, which I know for a fact is.
#25
1 Post
Over the last couple of years I have replaced: Steering Rack, Inner and outer Tie Rods, Poly Steering Rack Bushings, Poly front Anti-Sway Bar mounts and end bushings, Rear Anti-Sway Bar end bushings. I also keep the tires rotated and ballanced. My Bilsteins are in good shape also. It rides great and goes straight down the highway better than most new cars.
#26
My 98 wandered like crazy, too. Hitting a pot hole at anything over 40mph sent the front end hopping all over the place.
I switched out the struts/shocks, but didn't remedy the problem. I was going to get new steering rack bushings, but it was totalled before I could do that. Also did new sway bar bushings, endlinks, but didn't help.
It's probably the steering rack bushings, ball joints or tie-rods.
Kcannaday
40
03-26-2021 05:59 PM
Yotadawgjr
10
08-23-2015 10:51 AM
