disrupting trac control in 2wd runner**
ok ok so 2002 4runner, 2wd.
im used to pulling this plug out...the one directly below the brake fluid res.
when i pull this my gauge lights up like so...
signaling that abs is interupted and the traction control system is not working.
what id like to do is wire in a switch between the abs module and this plug so i can stop having to pop my hood and pull the fuse or unplug this signal wire.
this last picture is of the amperage of both abs fuses. i believe the 60A fuse is for the abs module itself and the 20A is for the ABS signal.
so would i be golden using a 20A rocker switch?
also there is 3 wires...red, black, white. im guessing white is signal, black is ground, and red is hot?
justdifferentials
Just Differentials
06-13-2022 08:40 PM
May-39
09-06-2015 02:05 PM
