Disc brake grease? where to buy/what else can I use?
Old 08-12-2003 | 09:46 AM
Los Gatos?'s Avatar
Hey, I need some disc brake grease. Noone around here seems to know what I'm talking about, so I am wondering what type of grease this is? Can I substitute a lithium grease or something like that? This is to change the brake pads on my front brakes. Thanks.
Old 08-12-2003 | 09:49 AM
loosehead's Avatar
I've gotten it at Napa and Autozone before, they should have it. It comes in little plastic tubes like ketchup at fast food places. Maybe ask for disc brake anti-squeal lube? I wouldn't use lithium or other...
Old 08-12-2003 | 09:55 AM
Los Gatos?'s Avatar
I will go to Napa. I went to Advanced Auto Parts, but they are a complete joke and didn't have ANYTHING useful in the entire store. Whew now I can do brakes. Excellent hehe.
Old 08-12-2003 | 10:04 AM
loosehead's Avatar
Good brakes are a "Must Have" IMHO, Good Luck!
Old 08-12-2003 | 10:23 AM
wimpywade94's Avatar
i just carry a big old anchor and out the window it goes when i want to stop.
wade
Old 08-12-2003 | 11:08 AM
Los Gatos?'s Avatar
Well for the past couple weeks I've just been going from drive to 2 to slow it down, and if I really have to stop I just dump it into 4-low, then park once I'm down to 10-15mph. It's worked okay so far, but obviously it's not good long term.
Old 08-12-2003 | 11:15 AM
seafarinman's Avatar
There is a spray on anti-squeal compound that I have used. They had it at the local base auto hobby shop. Just spray the stuff on the brake pad backing plate, let it dry, and install. The stuff is a lot easier to use than the normal silicone stuff, and less messy. I wish that I had a brand name and part number!:pat:
Old 08-12-2003 | 01:56 PM
zedex's Avatar
I just bought some of the stuff. Its called CRC disc brake quiet. Its pinky red in a small bottle. 5 bucks or so. Works great.
Old 08-12-2003 | 06:59 PM
amorphous's Avatar
anti-seize
good ole' anti-seize will work well too. Brush it on the backs of your shim plates and a bit on the backs of your pad and your golden. Don't forget the caliper bolts too, before you torque them down!
aaron
Jcrawl94
10
10-24-2015 05:34 PM
Peevedkitten
11
08-31-2015 07:57 PM
ojm3
08-28-2015 01:26 PM
priest16
15
08-06-2015 08:43 AM
bobpat
08-01-2015 10:25 PM
