Disable ABS on snow
Old 02-17-2014 | 12:14 PM
fastvrod's Avatar
Disable ABS on snow
Hi everybody
I have 97' 4runner and try to put switch to disable abs on snow.the easiest way is to pull the fuse but who wants to pup the hood everytime.had this done once before but cant find the diagram.any help be greatly appreciated
Old 02-17-2014 | 01:02 PM
Nelsonmd's Avatar
Does your 4runner have the rear locker? If so then it's a pretty simple hack to spoof the ECU into thinking the diff lock is in place and deactivate ABS, otherwise it's a bit more work to get a switch installed.
Search here and on T4R.org, I know both methods have write-ups either here or there.
Search for grey wire mod and blue wire mod.
Old 02-17-2014 | 02:02 PM
fastvrod's Avatar
do not have a locker.will search for the mod.thanx
Old 02-18-2014 | 04:59 AM
wyoming9's Avatar
Red face
Why not just pull the fuse and be done with the ABS Brakes .
I just hate them and that is one of my first moves that and cruise control and DRL`s what a waste
Old 02-18-2014 | 05:54 AM
Texmax's Avatar
Why in the world would you want to turn OFF the abs in the snow?
Old 02-18-2014 | 07:25 AM
Jomoka's Avatar
Snow, and gravel, is a surface where a locked wheel will perform better than a turning one. It allows a little pile of stuff to build up in front of the wheel, and for the wheel to dig down through the loose surface and into a little more solid stuff.
Personally, I think you're still far better off having ABS working on pavement, but that's just my opinion.
Old 02-18-2014 | 08:10 AM
Texmax's Avatar
A locked up tire perform better than a tire that is rolling and steerable? Totally ludicrous! You my friend are in the minority with that statement. The whole reason ABS was created was to keep the tire in motion so as to have more control. Hi, welcome to reality! Here's a little education for you.
http://en.wikipedia.org/wiki/Anti-lock_braking_system
Old 02-18-2014 | 09:47 AM
94 Newbie's Avatar
Smile Quick FYI
I heard of this , and a quick web scan produced this : Linky on ABS in Snow/Gravel
Like most technology, it is not 100%.
Britt
Old 02-18-2014 | 01:24 PM
Jomoka's Avatar
Not on loose surfaces, like gravel or snow.
And I agreed with you that on pavement and solid surfaces, ABS is a good thing.
As for educating myself via your link, if YOU read it you'll find this little bit:
ABS generally offers improved vehicle control and decreases stopping distances on dry and slippery surfaces for many drivers; however, on loose surfaces like gravel or snow-covered pavement, ABS can significantly increase braking distance, although still improving vehicle control.[1][2][3]
Old 02-19-2014 | 08:14 AM
Red Leader's Avatar
First winter after getting our '98 runner, first snow on the ground I took it out, driving normally (very, very conservative 'grandpa style' driver), going about 10 mph on a side street coming up to a T intersection and I slid 15 feet out into the middle of it. Had zero braking power. ABS kicked in. It didn't really pulse, it just made a grinding sound and I had no brakes. The 'runner basically just coasted right into the street. How the heck that is safe I've never know - makes me want to smack the engineer
Soon after that, I just pulled the fuse - it is much, much more predictable in the snow now and I'll never go back!
The consensus I've heard is that for dry/wet pavement it has its place, but at least in these vehicles, it just sucks in the snow. I understand why they put these safety features in, but I grew up on unsafe vehicles so I'm used to it
Anyone know how the ABS in these models compares to the ABS in other makes? Is ABS = ABS anywhere, or does each maker approach it differently?
JimiJams
09-28-2015 07:14 PM
Project90
09-25-2015 12:40 AM
JamesDINAN
09-22-2015 06:37 AM
matt1833
09-16-2015 08:11 AM
zz_denis
09-06-2015 04:43 PM
