Differential Breather Mod w/pics
On my old truck, I did the full diff breather mod - all the way to the engine compartment. On my "new" 96 4Runner, I just wanted another 6-12" of stream crossing capability (top of the wheels). Here is the link for those of you who want check this install out. It took me a total of 20 minutes from start to finish.
Required "extra" parts:
1 Toyota differential breather (in addition to your stock breather)
Up to 12" of vacuum tube (get the same diameter tube as the threads on the breather) I used 7" length tube because that's all that I had.
2 squeeze-on hose clamps
1 zip tie
I hope you find the write-up informative and helpful. Its REALLY easy to do, and just might save you excess wear and tear on your rear diff. Later!
1 zip tie
Guest
That's an interesting take on it...it should still keep you safe from the water though.
A lotta other people (myself included) route the end much higher up, but I dunno...you will probably be safe.
I'm sure they'll chime in with links to their pics. I have none...
Jim
Jim
Yeah, I would have gone with a longer tube if I had one. But for now, I will stick with the 7". I can always buy some longer tube. But this was free for me (I had all the parts sitting around in my garage)
is there a breather for the front ifs diffs? how does that work? is there also a tranny and transfer case breather?
i thought i remember hearing bout those before. not sure .
The original pics to this thread probably dont work anymore because picturetrail cut me off.
This is an idea for the front and the rear...
so you can use the same part for the front diff? man, stupid toyota parts guy. he said there isnt one. i asked, "so the front diff doesnt breath?" he said "no" . im all "ok" . i have to go back and order it again. :T
thanks!
thanks!
thanks!
thanks!
thanks!
thanks!
I believe the transfer also has the same style breather and you may want to extend it too. But, I think it's pretty hard to get to.
Steve
Originally posted by Robinhood150
It's just like the rear one with the valve. You still have to extend it. The problem is that the oil pan (I think it's the oil pan) is really close to the breather so you will need to either cut any fitting you use or get one with a 90 deg elbow.
Steve
Steve
thanks!
thanks!
Originally posted by <96 Runner>
Check this out. All you have to do is take apart the stock "head" right where it is by prying off the "cap." Then you attach a vacuum hose (like the one in my picture) and then you put a new breather from Toyota on the end of that. You never even have to get under the truck (for the front).
Steve
For the rear diff. breather (I finally got to it last week) I just ran tubing up to the gas cap with a new union and breather from Toyota. I'd been waiting on the front, based on what I'd read on the tight space. Unless you've got real flexible tube, its going to get pinched by the tight angle it has to make, and are probably better off getting an elbow fitting so the tubing will lie flat, at least that's my thinking anyways.
Hey 96Runner,
Where did you get that yellow tubing? I would like to get some of that so I can replace mine. Nice looking picture and set up. Please let me know where the heck did you get that tubing. Thanks.
Noel
1 Post
For the front diff on 1st gen's - you're stuck with modifying the stock breather. The replacement unions are too long and don't fit under the oil pan. A 90deg. union would be great, but you can't thread one in because the hole is too close to the rest of the case - union won't spin w/o hitting the case. Like was said earlier, just pop the top off of the original, attach your extending hose (& maybe some sealant to be safe) and clamp it down.
Has anyone been able to extend the transfer and tranny breathers on a 1st gen?
front diffy breather
are the stock breathers on the transmission and transfer the same as the ones on the diffys....so i know what i am looking for........
TheBFA
02-15-2020 06:55 AM
Odin
09-26-2015 06:56 PM
1997, 4runner, breather, diff, differental, differential, elbow, front, ifs, mod, modification, rear, reunner, tacoma, toyota
