Difference between 2.5" lift and 3" lift
Old 08-09-2009 | 08:20 PM
96Tacoma4x4's Avatar
Question Difference between 2.5" lift and 3" lift
Is there a difference between say the Dayster 2.5" lift and the Revtek 3" lift? I been looking around, and it looks like the pieces are different, I would think that they would be fairly similar even because they are different brands?
Thanks for the help!
Old 08-09-2009 | 08:59 PM
CYi5's Avatar
I guess I have to be the person to say 0.5" of lift. Search around for the different types of lifts (spacers, top outs, adjustable coilovers, adjustable struts) and you'll find what you're looking for as well as the pros and cons of each system.
Old 08-09-2009 | 09:01 PM
brian2sun's Avatar
As far as I know, the Revtek lift comes with polyurethane and metal spacers to be used together. The Daystar is all poly. They are pretty much the same, the real difference is that 1/2".
Old 08-09-2009 | 10:51 PM
sorry I guess I should have said that one difference is 0.5" of lift, but what I meant to say is which one is better because the 2.5" lift uses extended shackles in the rear, and the 3" lift uses lifting blocks and u-bolts for the rear?
Which is the best brand of 2.5-3" lift that is on the market?
Old 08-10-2009 | 07:12 AM
crolison's Avatar
neither are good, get a real lift.
some springs or coilovers up front and shackles in the rear
09-04-2015 10:27 AM
4Runnin2000
07-29-2015 07:09 PM
coffey50
07-28-2015 11:55 AM
justdifferentials
Just Differentials
07-22-2015 09:26 PM
msane99
07-11-2015 09:08 PM
