CV's Binding?!
CV's Binding?!
So I've had my driver side Inner CV Boot split for about 3 months now. I put more grease in it yesterday, but both CV's are still popping. I'm replacing with the NAPA CV's. Is their anyway I can make them stop until I have the new Cv's?
how much are the cv's from napa with the lifetime warranty?.. also from someone who told me this at work, that if you offroad and it shows they will not warranty them.. just figured i would say that..
They are $70. What Napa doesnt know wont hurt them . Went and priced OEM ones at $416 EACH! Quick question, I can still engage 4WD, would that still make them broke?
Well, anytime you see a rip in the boot, you're pretty much going to have to buy a new one or try to rebuild the old (not recommended). Dirt gets into the joint and gradually wears out the parts. No way to fix that unless you completely rebuild or replace.
I've used NAPA axles before (not the reman'ed but NEW). They held up solid. Autozone axles are good, too (again, new). But I believe they both sell the same axles from the same manuf.
Supposedly these are the NAPA Name Brand. Are GSP's any good? I'm not saying they aren't broke, it sounds in person like they are, haha . I just dont' understand how if they are broke, how they can still engage in 4 WD.
well they arent broke broke, they arent snapped in half. which boot ripped? im going to guess the outter. something is broken inside the joint, it will still work as a cv, but it really is a ticking time bomb with load applied in 4wd.
i dont see that you have manual hubs, so im assuming you have the ADD still in place. this will cause the cv's to spin even when not in 4wd.
do you have a diff drop with your lift? in my opinion that is absolutely necessary with any lift.
as for the popping of the joint, the inner joints are pretty simple (not nearly as complex as the outers) not sure what component in there would be popping.
how long do you have to wait for the part? seems like it should be only a couple of days if they were not in stock to begin with.
I have a 1" diff drop. As for the part, I'm pretty sure NAPA has them in stock. But I went for 1.5 months and wheeled it once on a decent trail without the drop. I just hope replacing it will fix it.
Well...they have been replaced. I still have a popping. My custom panhard bar has really big thread (it is a tool made for a crane) so the threaded part can play about 1/8" when the back articulates. I think this is causing tthe popping, however, it seems to be coming from up front. I know that vibrations and sound can transfer causing a mental fart, but, anyone have any ideas? I'm going to make a new panhard with very fine thread.
The pop from the front seems to be coming dirctly underneath where the gas/brake pedals are. Especially when I sway from side to side. can I just use some kind of synthetic grease on all zerks? And I just put grease in until it starts to come out of the zerks, correct?
Check all your bushings up front, starting with the sway bar bushings. Mine were shot and basically missing thus allowing the bar to contact the frame. Could be something like that causing the noise you're hearing. Jack up the truck, get a long pry bar or pipe, and pry on stuff to see if anything is moving more than it should.
Mine pop but it is the bushing on the Mcpherson strut. It pops over every bump that I hit and can do nothing about it until a new strut or bushing is replaced... So I said SAS!!! Thats where I am now.
Check you rubber on your strut bushing and if it is cracked or punctured then that is probably it. A lift puts so much extra force in that one part.
