Cv axle removal tool?
Old 05-11-2014 | 05:02 PM
FJHammerHead's Avatar
I need to replace my cv axles and don't feel comfortable using a pry bar. I was wondering if this tool I found on eBay would work? It seems that there are different sizes out there.
http://www.ebay.com/itm/Inner-Puller-Set-CV-Joint-Removes-An-Axle-Assembly-From-The-Transaxle-/331178504275?hash=item4d1bc6f053&item=331178504275&pt=Motors_Automotive_Tools&vxp=mtr
Thanks
Old 05-11-2014 | 05:17 PM
rworegon's Avatar
A small pry bar with gentle persuasion pops the CV right out. The CV has a couple of indents 180 deg apart that catches the bar or just place it in the gap between the CV and the diff. It does not take a whole lot of force to pop the CV out especially if your rotate the CV and pry like every 60-90 degrees.
Here is habanero removing hers in post 310. I remove mine the same way. The FSM recommends using a brass drift placed in the indent and a hammer.
Another thread showing the indents, etc. From another forum....a nice how-to.
That said, the tool you show should work too.
Old 05-12-2014 | 12:13 AM
wyoming9's Avatar
Red face
I would be curious just how you would get the slide hammer type tool in against the differential.If you do get this please tell us how it works
I popped mine out with a pry bar about 14" long if you rotate as you pry they pop right out.
Brass drift to get them back in a few good hits
Old 05-12-2014 | 09:43 AM
2Whlin's Avatar
There are spots where you can get a long brass punch on and one good wack and it pops right out. It's not that big a deal.
Old 05-12-2014 | 11:39 AM
250000_yota's Avatar
I'm with Oregon on this one. I use a 36" pry bar at work. Finger pressure and the axle pops out. If I happen to bend the dust shield in the process, i straighten it out. No big deal.
On another note though, I have found that the newer axles are definitely held in much more stoutly than the older ones. With the previous generation tacomas and 4runners, I could usually use a longer screw driver to pop them out, but I've noticed with the new trucks, it takes a bit of persuasion, and sometimes, trying a spot, then rotating to a new spot
Old 05-25-2014 | 03:21 PM
Well, rented the tool but didn't even use it. I wanted to have just in case. This job was as easy as everyone said it would be. I think having an extra pair of hands made all the difference. First side took us an hour and the second about 30 minutes. Thanks for the advice on changing these.
polo451
13
11-20-2016 08:49 PM
TJWilly
07-31-2015 03:05 PM
dfarr67
07-30-2015 08:08 AM
greenbuggy
3.4 Swaps
07-23-2015 12:51 PM
ItsJustD
07-07-2015 08:49 AM
