Customized 4xInnovation Slider Steps - Pics
#25
O.K., so after washing the truck this past weekend, I discovered that some of you were right. The water did puddle up on the plates, and fill the depression with water, worse than I thought it would. Easy fix though, I will just drill a couple of 1/4" holes in the corner of each plate.
So, if you decide to do something similar with your sliders, make sure to include some type of drain holes/slots in your design.
#29
I drilled all those holes with a hand drill.
Just kidding, found the steel at my local hardware store. Here is the top view.
This is a very worthwhile modification. It significantly helps prevent rock chips on desert roads.
Damn! why did you have to temp me! now i'm going to hae to get that done.... = more cost haha... i like the top coat you got on there!! is that truck bedliner spray? and a strip of grip tape?? if you have time, check out my post... its somewhat related.. https://www.yotatech.com/forums/f2/w...jipped-183233/
#30
I know the feeling. The more modifications I find online the more I feel I have to do!
The paint is regular spray paint...can't remember the brand but it's metallic black. And there's a 1" wide strip of grip tape down the outside bar. The grip tape is pretty much never coming off, so when I repaint the sliders I cover the griptape with 1" wide blue masking tape, then peel it off after painting--works perfect!
06-01-2021 01:51 PM
94ofCanada
08-14-2015 06:37 AM
priest16
15
08-06-2015 07:43 AM
