crank shaft bolt
Yeah, they're very hard to loosen. If you have an impact wrench try that. If not you can try using the starter. Get a 24" breaker bar and a deep 6-point socket, put the socket on the bolt with the bar under the passenger side frame rail. Then hit the starter for a second, you don't need much. Make sure the ignition system is disconnected first. That usually gets even the stubborn ones loose.
TJWilly
07-31-2015 03:05 PM
v_man
07-23-2015 05:01 PM
Iceman4193
07-15-2015 05:48 PM
