Could not find good starter removal pic so posted one..
For all of you that have removed the starter on a 3rd gen V6 auto 4WD 4runner, the write ups are excellent but knowing exactly how to orient the starter to remove it under the passenger side fender well can be challenging.
I just did mine and it was like a game of freakin tetris
Anyhoo, picked up contacts for $22 and starter is back in and working like a champ.
Here is the pic and note several things.
1. Bracket holding brake line is normally on the INSIDE of the frame rail. Remove bolt holding this bracket and the one on the outside of the fame rail closer to the flexy hose.
2. Lift bracket up and move to above frame rail...if you leave it where it is, it snags the starter.
3. Compared to its installed position, the starter is now back to front and upside down. Note location of switch contact.
This will save you a LOT of fidling as trust me, I turned the starter every which way until I got it out so took this pic so I knew how to re-install.
From leaving Yota stealer with parts to back on the road was around 45 mins today so it went back in really quick
David
David
Good info and picture. I added your thread... https://www.yotatech.com/forums/f2/4runner-starter-remove-removing-removal-replace-replacing-contacts-tips-how-89042/
Roger at 4crawler identifies them and sells them at his site...
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
David
voiddweller
19
05-02-2016 10:10 PM
bigblue82
10
07-06-2015 09:27 AM
FS[MidWest]: 2001-02 Tacoma/4Runner M/T Harness 3.4
greenbuggy
06-28-2015 11:40 AM
XtremeOff-Road
16
06-27-2002 08:32 PM
