Coolant Leak Question 3.4L Engine
Pull off the timing belt cover and see if your water pump is leaking. I have a slight leak on my 98, have seen pics on Yotatech that look similar, where it leaks on the passengers side of the pump. I had about 70K when my fan pulley bracket went, that is why I was inspecting... I plan on doing the TB and pump this spring after it warms up, actually have the parts waiting to install...
Avenged
07-09-2015 08:55 AM
