Compresion in a 22re
Originally Posted by bike4miles
I was wondering what is the ideal compresion range for a 22re? Mine is about 75 to 70psi, is that good?
Originally Posted by alanbobalan
what kind of shops do compression tests? just curious...
You can do a compression test by yourself.
Just remove all the spark plugs and thread the compression tester into one cyliner. I usually set it on the motor so I can see the dial because the first crank psi is just as important as your final crank psi. Hold the throttle WFO and crank the motor at least 4 revolutions making sure to see what the first crank reading was.
Jayboy74
10
12-21-2021 09:27 AM
