Code 0171
Old 07-03-2013 | 09:45 AM
Flightguy's Avatar
Code 0171
So, I'm getting an engine code 0171: system adaptive fuel too lean. And I don't know what that means. I just had my 2000 4runner tuned up, replacing the plugs, wires, and one ignition coil that was bad. Fixed a lot of my issues, but this popped up.
The shop suggested replacing the O2 sensor, and it might fix the code. Not sure that believe that. But it's something else I could do myself.
Any thoughts from the knowledgable forum on a way to fix the code issue? I have Georgia emissions coming up very soon, and it WILL fail if I have any engine codes.
Old 07-03-2013 | 11:14 AM
250000_yota's Avatar
Try cleaning the mass air flow sensor. I've seen quite a few get fuzz and dust built up on them, making them give false readings and thus a check engine lit.
Old 07-14-2013 | 01:12 PM
Flightguy's Avatar
Ok. Still need a little more help please. What I've done. the plugs, replaced the fuel filter. Cleaned the maf. I've not seen any o2 sensor codes. Any other thoughts?
Edit: removed text that shouldn't have been there.
Old 07-14-2013 | 01:27 PM
rworegon's Avatar
Check for any loose or cracked vacuum lines, including the air intake flexible tube to the throttle body.
Air cleaner in good shape?
Old 07-14-2013 | 01:32 PM
tantacoma's Avatar
My '99 FSM lists other possible 'trouble areas' that could cause this:
loose air intake hose
fuel line pressure
injector blockage
coolant temp sensor
gas leakage on exhaust system
Not sure what the last one means
Old 07-14-2013 | 02:08 PM
Flightguy's Avatar
Used half a can of brake cleaner. Couldn't find any leaks in the vacuum system.
And the air filter is pretty new.
Old 07-14-2013 | 02:53 PM
rworegon's Avatar
Take the intake flexible tube off and give the ribs on the bottom side a good inspection. It's tough to get brake cleaner, etc. on the bottom side.
Are all the plug boots on tight? Check all the other electrical connections too.
moparbay
10-06-2015 10:24 AM
bradahman
10-01-2015 10:24 AM
charlie_fong
09-27-2015 11:06 PM
Odin
09-26-2015 07:56 PM
Draven023
09-26-2015 01:41 PM
