Clutch problems
Old 03-14-2013 | 09:21 AM
turbo8's Avatar
Question Clutch problems
97 4runner 5spd 4x4
Some how air is getting into my hydraulic system but im not losing fluid. This happened the other day while driving to work, previously it was working fine
Ill bleed the system and have a nice firm pedal, I will then go for a test drive get a few good shifts then the pedal loses pressure.
I have swapped out master and slave cylinders and have the same problem.
other stuff I have done:
Removed the torsion spring from clutch pedal a couple years ago.
sprayed some high temp grease on clutch fork pivot to stop it from sqeeking
I don't have a clutch pedal return spring on, its been like that for a year, should I put one on?
what should I do next?
Old 03-15-2013 | 04:10 PM
wyoming9's Avatar
Red face
In all of your swapping around you have a poor connection some place .
allowing air to be pulled into the system.
It does not take much just a little bit of dirt will cause this to happen.
It could even be the bleeder valve that is causing the problem
the1998sr5
15
07-14-2020 09:35 PM
PlayAwhile
07-20-2015 12:36 PM
1996Taco
07-20-2015 01:02 AM
the1998sr5
07-16-2015 07:20 AM
Kalihi,HI
07-09-2015 05:29 PM
