clicking clutch pedal
hey fellas, ive read a bunch of posts around that talk about a squeaking clutch pedal and replacing the bushing, im getting a click when i push in the pedal, anyone else getting the same thing?
Mine squeaks pretty loud, sounds like its from in the cab but it was actually from under where it goes into the clutch.
theres a rubber boot that is ribbed and has two square openings in it. I sprayed wd-40 in there and it fixed the squeak for about a month or so but it keeps coming back. i was thinking of trying a wax-based lubricant next because i don't have the time to get in there
yeah mine has that annoying groaning, im pretty sure its the release bearing, ill be replacing the clutch and all that in a month or so so thatll be a thing of the past, im also hearing a tick, or a click sound when i press the pedal down, its annoying as hell, and i cant figure out what it is, ive lubed the pedal, bushings, spring and it wont go away... any ideas??
Shaun Crystal Gomban
07-30-2015 10:13 PM
