Check engine light help
Old 05-20-2009 | 03:28 PM
irunner's Avatar
My 4runner has been getting terrible gas mileage, jumping at stop lights, idling high and loss of power. I went to Autozone to get the codes and it came up with this. I have a 1997 4runner V6 SR5 2wd with 162,000 miles.
P300
P302
P304
P305
P306
Old 05-20-2009 | 03:45 PM
toyota4x4907's Avatar
P300: random/multiple cylinder misfire detected-- Misfiring of random cylinders is detected during any particular 200 or 1000 revolutions
P301-306: Misfire in corresponding cylinder. In your case cylinders 2, 4, 5, and 6.
Old 05-20-2009 | 03:47 PM
irunner's Avatar
I'm guessing a new set of spark plugs is in order?
Old 05-20-2009 | 03:54 PM
Might as well start with new plugs, wires, etc. Could be like the coil packs or whatever the 5VZ-FE has.
Old 05-20-2009 | 04:23 PM
irunner's Avatar
What spark plugs do i need? single or double? are they different on each side?
Old 05-20-2009 | 09:09 PM
SnowRunner98's Avatar
I got double, the sticker on the front of the motor--told me too. there was single prong autolites that were wore out that i changed. not sure how much double vs. single matters though.
Old 05-20-2009 | 09:40 PM
Kiroshu's Avatar
Tune-up!
Old 05-24-2009 | 08:00 AM
osin's Avatar
I had similar problem and changed all spark plugs and wires.
After two weeks problem returned with misfire codes: 300, 303, 305 (dealer said there was 50% cylinder 5 misfire).
They changed all (3) ignition coils and so far no problems with misfires or check engine light...
Old 05-24-2009 | 08:45 AM
mt_goat's Avatar
Read this over, but the high idle points to a vac leak somewhere (unmetered air is getting in after the MAF) Of course you could have more than one problem.
https://www.yotatech.com/forums/f2/c...ighway-128206/
Old 05-25-2009 | 10:38 AM
irunner's Avatar
Changed spark plugs and wires and nothing much, ordered a Denso O2 sensor from Amazon.com for $68, putting it on Thursday.
Old 05-28-2009 | 10:24 AM
irunner's Avatar
UPDATE: Put in the sensor and my car has never sounded so good, idles right at 700, no more CEL, i don't think my car has ever ran so well.
Old 05-28-2009 | 01:20 PM
good to hear
bigjstang
08-25-2021 01:41 AM
06-01-2021 02:51 PM
Kalihi,HI
07-09-2015 05:29 PM
God's Bounty Hunter
07-08-2015 01:54 PM
colinmil
07-06-2015 05:03 PM
