Check engine light diagnosis tools?
'98 4runner SR5 V6 Auto 4x4 94250 miles
My check engine light came on today, and I need to figure out why. My Toyota dealer is $97 an hour so I'm not real eager to take it to them. I'm not 100% on the local toyota shops, and besides, I would like to do it myself if possible. It's more fun that way.
So what tools do you people use to figure out the reason for the check engine light? one of those little hand held code readers or something that connects to a PC? Would one of those little OBDII readers that stores info to a memory work?
Should I just take to the shop?
Go to an advance auto, autozone, napa, or any auto parts store and ask them to pull the code for you...
they almost never have a problem doing it..just write the code down and come back to the forums!
I was thinking that a code reader might be a good investment. Is there something I should look out for when buying a reader? I'm looking for one without a requirement for a PC. I want a little hand held code reader, or one of those memory based things.
(like this http://www.davisnet.com/drive/produc...p_products.asp)
Does anybody know if these little car chip things would work for getting a code? or will I have to get one of these http://www.midwayautosupply.com/deta...ption.asp?3352 type things? or would I have to get one of those ones that hooks up to the OBD2 and PC at the same time?
I've searched and red the millions of posts on these things and I'm still left in the dark. From what I read, it looks like most of you are using the OBD2 to PC connection type readers. I didn't want to do that, so I was trying to find another way. Maybe I'm just dreaming.
Oh, and my Autozone wants $200 deposit (incl. tax) of which the non tax part is refundable, or so the guy said.
Most people on YT use one of two systems:
1) Windows PC based ($100 on website) - http://obddiagnostics.com/
2) Windows PC or Palm PDA or based ($150-200 ebay) - http://www.auterraweb.com/
The reason they are fairly cheap is because you are using the PDA or laptop as a display, so all you really need is the interconnect hardware and the software to run it.
Originally Posted by MTL_4runner
Kevin, the type of scanner you get really depends on what you want to do with it. If all you want to do is read codes, then either of the 2 you mentioned should work fine (not sure on the first one but definately the second). If you actually want access to all the sensor outputs then you'll need something a little more sophisticated.
I don't really have a laptop or pds handy, so that would be additiona costs for me. But it makes sense.
"I have one of the EQUUS readers and love it. I use it on all my family and friends '96 and newer cars. I have used it to diagnose a couple of problems on my runner and fixed myself."
What Equus do you have? I think there are 2 OBD2 models. The 3100 and something else that I forget. :pat:
Thank you both for your help.
Originally Posted by surf4runner
that is not free, nor legal. talk to the manager or the BBB.
I got the Actron one they sell at Autozone not the least expensive one but the next one up and have used on my truck a couple of times and on my Moms car several times. Before I got on the forums and I had the reader I took it to the dealer to check a code and basically paid 150 bucks so they could tell me that I needed to clean the MAF cause it got oily from my K&N. Wish I had just bought one to begin with.
Thread Hijack:
Does any of the code readers mentioned above use a paramter screen? The one i used when I was working for GM had parameters so I could read what was going on with the vehicle I.E. misfire datas, voltage supplies, and so on to more accurately diagnose a vehicle. I don't want to buy just a general code reader when I can actually have the ability to "see" what is going on with the vehicle. The only one I knew of for public use was a brand called VETEC but it was $10,000 yikes!
Originally Posted by Ironmike4x4
Thread Hijack:
Does any of the code readers mentioned above use a paramter screen? I don't want to buy just a general code reader when I can actually have the ability to "see" what is going on with the vehicle.
Know though that different vehicles will expose different parameters. Toyota trucks are pretty much the same across the board, but a Camry may be different, or a GM, or a Ford, etc...
I'm assuming that is different for the 3rd gen vehicles? For my '91, i picked up a little pin block that plugged into the diagnosis plug (i think is was just a jumper for two pins) and read the blinking CEL. Is it harder than that for my '02? Do you really need a scanner to read the codes?
Please enlighten - oh great yota board!
Originally Posted by Tragic Drive
I bought the Actron cp9145 for $200. from pepboys. This scanner display's alot of the sensor's values. So far it seems to be decent and I havn't had any problems with it .
I didn't realise that Actron had parameter access, Thanks! Also can you control any of the parameters? I know on the one I mentioned above you could adjust TPS, oxygen/fuel mixtures, ect. That would be great if it does.
The OBD II interface was (is!) a Godsend in terms of being able to get information about errors (too rich, misfires, etc) and general runtime params (ltft, timing advance, fuel consumption, etc) but yes... to use the interface you'll need a box.
You can buy a simple "code reader" for $30(ish) which will let you see the code number when the CEL is on. To do more, like read engine params, you'll need more of a box. The Actron is a good stand-alone example, Jamie gave an example (that we both have) for Palm handhelds and another for PCs, and there are others for both.
06-01-2021 01:51 PM
