Cheapest downey coils
Old 01-07-2004 | 08:31 PM
Robinhood150's Avatar
If you keep the stock length shocks then you should be ok without brakelines. The shocks are what limit the travel. If you plan on off roading it and travel is a concern then you'll want longer shocks. If you're not going to off road it, stock length shocks are fine. The brake proportioning valve should be adjusted though, either with a bracket or changing the length of the rod.
KING's Avatar
Aside from purchasing the coils, one also needs to separately purhcase the brake lines? Where?
Old 01-07-2004 | 08:36 PM
KING's Avatar
If you go with larger shocks at the rear, will you have to match the rear in the front?
Old 01-07-2004 | 08:47 PM
fooddude's Avatar
im not planning on switching shocks just the coils. Because im only 17 and cant afford shocks and coils. Mainly because im saving up for new tires and a body lift.
Old 01-07-2004 | 09:59 PM
  #25
Up front the travel limits are defined by the bumpstops, not the shocks. You can get about an extra inch or so of droop by spacing the shock down with poly spacer. This assumes you have low pro bumpstops.
Old 01-08-2004 | 02:30 PM
  #26
Hey, I am not tellin ya what to do, lord knows... am too new to the forum, but I would dissuade a Body Lift on a 4-runner, if you think you can see that gas tank hanging down right now, just wait for the lift.... then the underlings start to show. I thought about doing the same thing to get some 33's, but just did an OME rear spring, and torsion bar crank, bout $275 out of my pocket. Food for thought....
Old 01-08-2004 | 03:26 PM
  #27
Scarbro22's Avatar
Hey sigep4runner359 welcome to Yotatech. I live in Chattanooga and wonder where you wheel?
Old 01-08-2004 | 05:17 PM
  #28
Last time I went, I still was in Va, we used to go down to the Jefferson Nat'l forest, but, I am always looking for some cool places to go here... I have heard about some from my cousin down that way, in north ga, and in the cherokee nat'l forest, but haven't been out to try any yet. How about you? Got any suggestions?
Old 01-08-2004 | 06:13 PM
  #29
fooddude's Avatar
alright people time to get focused again i really need these coils soon. Stay focused, stay focused.
Old 01-08-2004 | 06:25 PM
  #30
Scarbro22's Avatar
Someone please help fooddude out in finding his coil springs (i am personally ordering mine tomorrow (if my dad will finally help me out) from Central 4WD!! But in the meantime:
When I have time to go me and a church buddy go to the local State park called Prentice Cooper which is decent with a good creek crossing and some mud and rocks. I want something with more to choose from like at Wheelin in the Country in middle TN www.wheelininthecountry.com . That place looks great but is 3.5 hours away and since im still in highschool i don't have enough time to go out there and really spend some time. I don't know exactly where Franklin is but i'd check that place out for sure.
MadMax48
03-03-2020 11:33 AM
the_supernerd
10-01-2015 10:20 PM
mojo4x420
09-16-2015 09:07 AM
HiLuxer
09-09-2015 03:43 PM
