Cheap mod from Xtreme Off-Road
Velcro would work, however they come with some 3M double sided foam tape. There'a also instructions for screwing them down if you want a more permament effect!
Originally posted by <96 Runner>
Jim-
I'm not sure anyone wants to do that research for you.
Jim-
#29
Its not hard to see at all. I can see mine thru the space in the steering wheel. I was actually going to take a pic from that angle, but forgot to!
#33
#34
Originally Posted by asudan96Runner
Hey I might be down for the ISR mod also. Does it work for S/C'd runners?
I'll see you guys saturday.
Dan
Dan
#36
GoodTimes,,
Thanks a bunch!!
I ordered 2 from Mike, but I just wanted to see what they looked like in your truck and where you mounted them. Soo ... thanks! Have fun out there today and tomorrow and Sunday!!! I'll be thinking of you guys!
Thanks a bunch!!
#38
After doing the ISR mod, I noticed my Runner doesn't seem to downshift as abruptly, or as often, when using the cruise control and pulling a decent hill on the interstate. With the IS removed, it usually smoothly drops into the 'passing gear' before dropping lower if needed. Prior to the ISR removal, it would bypass the 'passing gear' and downshift much more harshly (directly into 3rd I believe) causing the RPM's to jump quickly on the same hill.
Other than that I haven't noticed much else...
#39
#40
Originally Posted by 4route
GoodTimes,,
Thanks a bunch!!
Thanks a bunch!!
I got two for myself from Mike as well. I have one mounted above the Front Passenger Seat Belt Pillar. The second one is mounted above the dimmer switch for the interior lights.
Worked out to be the best locations. I copied lance on this.
