Changed brakes now no brake power
Old 03-02-2013 | 10:26 PM
blackout138's Avatar
I just changed my front brakes on the passenger side. While I was taking off the caliper, I loosened a bolt which had some brake fluid spill out. I tightened it as quickly as possible and then reassembled the brakes. Now I have no brake power. Did I destroy my brakes buy loosening the wrong bolt? Is this the reason for no power?
Btw, I have a 99 4runner 3.4L, 4wd.
Thanks.
Old 03-03-2013 | 05:14 AM
DRCOFFEE's Avatar
You let air in the line. If it works its way to the ABS or master, you need specialized equipt to rebleed the system. Try bleeding the brakes.
Old 03-03-2013 | 05:23 AM
Darryl01088's Avatar
Sounds like you opened the bleeder screw. You will have to bleed the brakes. You can buy a mighty vac http://www.mityvac.com/pages/products_hvpo.asp at most auto parts stores. Otherwise you will need two people. Suggest you consider taking the car somewhere and having the brake system flushed. Bleeding brakes is simple but it could take you hours if you are unfamiliar with the task.
Old 03-03-2013 | 05:29 AM
DRCOFFEE's Avatar
This is a safety issue. It needs to be done correctly.
Old 03-03-2013 | 07:35 AM
5runner's Avatar
yes take it some were! specially if you dont even know what you loosened! it is a rather important system on the truck!
Old 03-03-2013 | 07:42 AM
KZN185W's Avatar
you need to bleed your brake system to remove the air that went in when you opened the bolt.. and btw, it's a 3.4L not a 3.6L.
Old 03-03-2013 | 08:59 AM
Thanks.
Ok thanks. I've been looking for a good write up but can't seem to find one. I found one here. How does it sound?
Old 03-03-2013 | 09:01 AM
What kind of safety issue? Thanks.
Thanks everyone for your replies.
Old 03-03-2013 | 09:21 AM
KZN185W's Avatar
That should do it.
<img id="ums_img_tooltip" class="UMSRatingIcon">
Old 03-03-2013 | 09:33 AM
rworegon's Avatar
Seriously?? How hard is it to figure out that lack of braking i.e stopping is a serious safety issue?
Old 03-03-2013 | 09:40 AM
I thought you were talking about during the bleeding process, not the after effects.
ashersullivan88yota
01-18-2022 06:37 PM
06-01-2021 02:51 PM
Eggslinger
06-08-2019 04:32 PM
Johntom240
7
07-13-2015 01:18 AM
87turboPA
07-09-2015 06:58 AM
