CEL, Traction Ctrl Lights.. What did I do?
ok, would mine have two o2 sensors or just one? And is there any way to figure out which one is bad other than buying a new one and seeing if its a goner?
Ok, well o2 sensor, are you talking pre-cat or after the cat?
I got a used one off ebay, of course just seeing that it was a 4 wire one, and it got here, and wasnt quite the one for the truck. It did have the correct mounting, but I had to cut off the plugs and swap the connectors. It didnt seem to solve the problem unfortunately but I just pulled the EFI fuse, so i dont know if it cleared it or not. I disconnected the battery and will see if that works.
And I know you are only supposed to use Denso.. but anyone have any experience with these?
http://cgi.ebay.com/ebaymotors/O2-Ox...em140150786332
They run about $150 from any other source that I've seen, including Ebay.
#25
Sweet, thanks, thats a bit more reasonable. The sensor from them comes with the flange needed right? Not sure if that is just a generic picture or the one of the 4runner.
And I read on this forum that they were different from front to back, I guess i didnt look at that auction real well.
I am going to try to heat it up before I put it back in (I read somewhere that if you get the tip red hot it'll sometimes burn the stuff off and make it work) and since I have a non working one... why not give it a try before spending 75 bucks.
And thanks for the clarification that my code is for the front sensor... when i saw air/fuel, I figured technically it could be maf also since that'll somewhat control it.
#26
Despite what that Ebay ad says, the front (pre-cat) and rear (post-cat) are NOT the same. Your code, 1135, is specific to the front sensor which Toyota refers to as an A/F (air/fuel) A.K.A. a wide-band. The best price in the US is from http://www.urdusa.com/product_info.p...s_id=430006000
Sparkplugs.com sells that Denso part for $154, or the NGK equivalent for $380 if you're feeling rich.
and Aero, that code is specifically for the heater circuit of your front sensor. You can check the resistance of the sensor's heater at room temperature and full operating temperature to see if the problem actually lies with the sensor (most likely), or your wiring or ECM. See test procedure here.
#28
#29
Don't bother shopping because you won't beat their price for OEM O2& A/F sensors.
Yes, the A/F sensor costs more than a simple O2 sensor, but that's life.
#30
#31
#32
Well, I tried to test the ohms across the wires that it said in that link, and got nothing at all. Tried flipping the wires, and combinations of all of the wires and still got nothing. Tried it on another 02 sensor I had lying around, and it did get a reading, just to make sure the gauge was working.
So I guess I'll have to be buying a new one. Sucks, but hopefully I wont have to worry about it for a long while. Thanks for all the help.
#33
justdifferentials
14
06-11-2017 09:36 PM
Scotttekoch
09-28-2015 11:30 PM
charlie_fong
09-27-2015 11:06 PM
sonorn67
09-19-2015 06:39 PM
