Can someone check their swaybar?
Old 11-29-2007 | 05:13 PM
BajaRunner's Avatar
Hey guys,
I haven't had my swaybar in for over 12 months. I just finally got the L and R brackets which go around the front swaybar, and hug up against the larger bushings ON the bar, that go to the frame.
Im assuming L=driver and R=passenger side.
Can someone confirm this for me, and let me know which direction they go. They have one welded in bolt thread, where you put a nut on it, and the other one is like a welded nut, where you thread a bolt through. Which one goes in front??? <<This part is the most important.
Old 11-30-2007 | 09:32 AM
4Hummer's Avatar
Looks under front of truck.. "Nope No sway bars there"
Looks under rear of truck... "None there either"
Hymmm sorry cant help.
Old 11-30-2007 | 09:52 AM
BajaRunner's Avatar
Yep, I have the same thing, and now I cant figure out how to make them align! I don't get it. Maybe when I broke mine, something bent up on the frame. WTF!!
Old 11-30-2007 | 11:16 AM
BajaRunner's Avatar
Well, its always awesome to see how many thousands of questions Ive answered, yet I can't get one person to verify this for me?
Old 11-30-2007 | 11:27 AM
Tacoclimber's Avatar
Dude, if I had a Runner, I'd be all over it. But I took my swaybars off of my truck, and since it's a Tacoma, I doubt it would help you anyway...
Old 11-30-2007 | 11:33 AM
surf4runner's Avatar
im not looking under mine ('02) until the rain stops...likely later tonight
Old 11-30-2007 | 11:35 AM
fastkevman's Avatar
If you go to Toyota dealership parts department they can print out a parts breakdown sheet which will also show proper placement.
Old 11-30-2007 | 12:23 PM
BajaRunner's Avatar
Ok sounds good thanks guys
Old 11-30-2007 | 01:46 PM
eric-the-red's Avatar
Mine's at home, and I'm at work. I'll have a look tonight.
Old 11-30-2007 | 03:51 PM
RandyÄ's Avatar
The captive bolt goes forward, captive nut is in the rear. The L and R are from driver perspective. The slit portion of the bushing goes forward as well.
From experience, grease the bushing well with a marine grade grease lest you have to do it over when they start squeaking.
Old 11-30-2007 | 05:30 PM
Glad you answered, it's about -5 degrees here and I didn't really want to crawl under my truck to check
Old 12-01-2007 | 09:59 PM
kcebes's Avatar
My bushings in mine look murdered. Maybe i should remove it.
Old 12-01-2007 | 10:17 PM
JC_ez's Avatar
Only grease the bushings if they are polyurethane. Do NOT grease the stock Toyota bushings. The stock rubber bushings are designed to grab the sway bar tightly and twist with the bar. The bar is not supposed to rotate in the rubber bushing.
Blamalam
03-12-2022 08:34 AM
raptor510
08-19-2015 03:15 PM
129Creepin
08-05-2015 11:12 PM
jimkoz26
08-05-2015 04:15 PM
yourrealdad
07-29-2015 12:08 PM
