can i put 265/75/r16's on my factory 2002 taco??
Old 07-05-2007 | 12:25 PM
  #41
RETRO's Avatar
Versatile and efficient, Pro Comp All Terrain Tires offer everyday reliability on the road, and peerless performance in adverse conditions. Inventive lug design earns these Pro Comp tires a Severe Weather rating, while advanced tread patterns ensure even wear and maximum durability. The tread is designed with an elliptical siping pattern and interlocking shouldered lugs that provide extra bite and gripping power in snow, dirt, and sand. A dual radius tread arc gives these Pro Comp tires increased road contact for greater traction and maximum durability. Best of all, the Pro Comp All Terrain Tires are covered by a 50,000-mile warranty. As far as Pro Comp tires go, these don?t just drive on the road; they hug it like an old friend.
Radial All Terrain Structure ? Pro Comp's Advantage
50,000 Mile Street Tough Warranty ? Severe Weather Rating
Advanced Pro Comp Tires tread technology stomps the competition. Only the Pro Comp All Terrain has a 50,000 mile warranty and a Severe Weather rating, making them the ultimate Pro Comp truck tires.
Dualguard? Polyester Body
Dualguard polyester body plies consist of thick, 2 ply polyester construction blended with dual-side wall rubber makes them the most durable Pro Comp truck tires yet. Maximum puncture resistance with total flexibility, and low air pressure optimization with less heat build-up off-road is just the kind of versatility you expect from Pro Comp tires.
Elliptical Siping Pattern
These Pro Comp tires use deep siping throughout the tread and interlocking shoulder lugs to provide extra biting edges for excellent, all-weather traction. Patented tread pattern also allows for superior gripping power in snow conditions, giving these Pro Comp truck tires their Severe Weather Rating. Only the Pro Comp All Terrain has this feature.
Dual Radius Tread Arc
Dual radius tread arc maximizes the tread contact patch, giving this series of Pro Comp tires greater traction. Intelligent lug arrangement also maximizes treadwear and allows smooth, even wear throughout the tread life. Furthermore, Pro Comp Tires guarantees the quality of these the Pro Comp All Terrain with a 50,000 mile warranty.
50 Degree Triple Center Lug Design
Featuring high void siping with 50 degree interlocking center treads, these Pro Comp tires deliver excellent traction in dirt, sand and snow. Reinforced sidewalls and skillfully placed lugs produce even more traction, while also maximizing wear and performance.
Old 07-05-2007 | 12:38 PM
  #42
mkgarrison5's Avatar
the 4 runner's height is different from the tacomas. the tacomas i beleive sit lower than the 4 runners... i may still get the 265/75/16. i dont see it rubbing from some reason. i have plenty of well room left even with 245/75's... but you guys say it does. lol.. tough decision!!
Old 07-05-2007 | 12:54 PM
  #43
RETRO's Avatar
I thought you was putting it on a Tacoma..A 4Runner you'll be fine with 265/75/16 I put them on my friends 4Runner no rubbing at all and his is a 1994 stock...
Old 01-03-2014 | 05:48 PM
  #44
Toyotero's Avatar
This is an old ticket but right on topic for my question.
I'm planning to get 265/75/16 for my 03 Taco DC 4WD.
Regarding the mud flaps, the the bolt heads what contact the tire? Would some sort of flat head fastener resolve the issue like what Expeditions West did to the splashguard to fit 255/85 R16 tires?
http://www.expeditionswest.com/equip...bfg_mt_km.html
Originally Posted by RETRO
mkgarrison5 here is my 04 with 265/75/16 on it..I have some rub when I turn left and in dips..It is very minor you will have to remove the mudflaps if have not already did..
bigjstang
08-25-2021 01:41 AM
Road Bull
10-10-2015 05:55 PM
Tyler Cunningham
07-11-2015 11:18 AM
Poncho0206
07-10-2015 07:21 PM
