CALLING ALL SMART 1st GENERS
Old 06-06-2005 | 01:57 PM
drewberglund's Avatar
My bright's on my 87 4runner havent been working for some time. I have to get it fixed before I can renew my registration. I already replaced the headlamp switch in the steering column but that didnt help. Mechanic says its the combination switch which runs about $200 from the dealer. Anyone have experience with this problem or know of another way to get this part besides the yota dealer. I searched this already but didnt get a good answer.
Thanks y'all
Andrew Berglund
Old 06-06-2005 | 02:07 PM
4xJedi's Avatar
By combo switch does he mean the turn signal/headlight switch that's under the shroud? I've never heard of that problem before but definatly check out the salvage yards first. Try to find a 'pick-n-pull' to save some extra coin. Not positive but the same year pick up should be the same part. I think the relays and fuses control low and high beams so the combo switch sounds about right. Good luck.
Old 06-06-2005 | 02:18 PM
SupraSport's Avatar
yep.... junkyard pull. It'll cost you 5 bucks at most, tell them it's a relay
Old 06-06-2005 | 02:20 PM
colsoncj's Avatar
I've had this problem 3 times now....
Heres your quick and easy solution:
http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
You can thank Roger for it!
Old 06-06-2005 | 02:38 PM
4Crawler's Avatar
Yep easy fix, then consider adding a headlight relay kit to take the load off the tired combo switch:
http://www.4crawler.com/4x4/CheapTri...OnLineOrdering
Old 06-06-2005 | 03:50 PM
phorunninduke's Avatar
If it doesnt work out for you, i think i have a switch you can have for shipping cost.
justdifferentials
14
06-11-2017 09:36 PM
MaK92-4RnR
10-28-2015 03:45 PM
runnermedic
13
09-21-2015 06:20 PM
icentropy
09-10-2015 06:03 AM
Badfish740
09-04-2015 05:21 AM
