A/C Problem
Old 05-14-2009 | 12:09 PM
hotlavaaaa's Avatar
A/C Problem
For the past year or so I've noticed that the effectiveness of my A/C has been declining. The temp of the air coming from the vents is inconsistent. Looking through the site glass I see foam sometimes and I can't tell for sure, but at times it might be running dry so I know that I've lost refrigerant. Can anyone tell me if there are common points in the system for leaks to occur? How much will I be looking at to recharge the system if it has to be evacuated? Thanks.
Old 05-14-2009 | 05:21 PM
SoCalPaul's Avatar
You most likely have a leak. I'd try the canned refrigerant first, maybe get one with dye to detect leaks. Leaks occur at connectors & valves or you could have a leak in the condenser that is in front of the radiator. You may see a small oily residue in the area.
Old 05-14-2009 | 06:49 PM
BajaRunner's Avatar
Hmm, so the 3rd gens use R134-A refrigerant?
Old 05-14-2009 | 07:59 PM
hotlavaaaa's Avatar
Yeah.
MO transplant
04-23-2023 12:58 PM
stock87yota
07-31-2015 11:08 AM
jackiebrownia
07-20-2015 10:02 AM
TURBOrunnerNM
07-20-2015 09:31 AM
bryan34w
07-06-2015 06:53 PM
