a/c not so cold
a/c not so cold
anyone know how to recharge a/c, or possible links showing how,any info would be great.on my 99 tacoma 3.4 v6.and can i get what i need at a auto parts store. thanks ken
Is the compressor running? If so ..
You can go to Oreilys or parts store you like get a couple of cans of 134a,They will also have a cheap hose with a guage you can use to recharge it. Then see what you get. It is really easy.
Then if that seems to work see if it lasts or maybe you have a leak then get someone to fix the leak. Thay also make a small can of stuff that gets it about 10 degrees cooler. I added it to mine just because, its so cold it hurts now.....Good luck
I believe they say your AC is supposed to get really cold before it goes out. Maybe that's just me, but I could have swore... Hmmm.
Yeah, best bet is to see if you have a leak, if you are still good on R134, then it might be your compressor. And that can cost $$$!!!
Also, can you add a lower thermostat say a 180 compared to 195(not sure if that is what toyota uses?)
The T-Stat wont help your a/c that i know of, your heat wil be a shade cooler in the winter with a cooler T-Stat.
kawazx636
10-06-2021 03:03 PM
83yotastockR
11
11-10-2015 06:54 AM
bryan34w
12
09-30-2015 02:50 PM
